delete protocol
delete protocol {filter} filter_name
Description
Deletes a user-defined protocol.
Syntax Description
filter Deletes a protocol filter.
filter_name Specifies a protocol filter name to delete.
Default
N/A.
Usage Guidelines
If you delete a protocol that is in use by a VLAN, the protocol associated with than VLAN becomes none.
The following examples delete a protocol named "my_filter" and a protocol filter named "my_other_filter":
delete protocol “my_filter”
delete protocol filter “my_other_filter”
The filter keyword was added in ExtremeXOS 15.5.
Platform Availability
